Old-Biscuit
Jan 02, 2017Explorer III
Converter output goes thru 'reverse polarity' fuses then thru an in-line fuse (or DC circuit breaker) then to battery positive terminal (maybe thru a disconnect switch if equipped)
NEG cable will go directly to battery NEG terminal along with NEG cable to frame for ground
YOU have a bad connection (loose/corroded etc) on POS or NEG wiring
Just start measuring DC Voltage at each junction
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
