laknox
Jan 03, 2017Nomad
DReisinger wrote:
Check the battery disconnect, mine is by the door down low, apparently it had gotten bumped and turned off, replaced the converter, still low voltage at battery, flipped the switch and back in business.
My disconnect, when open, will show 0v, as it cuts off the battery charging connection along with everything else. Found that out the hard way. The only way I get =any= voltage from the converter is with the disconnect closed. YMMV...
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
