majorgator's avatar
majorgator
Walk-Through Inspection on Purcahsed 5'er
We just signed on the dotted line(s) for a nice used Forest River Wildcat Bunkhouse 5'er at Camping World. We waded through a lot of CW negativity from all over the place, and we believe we've struck an excellent deal on a unit that's in great condition. There are some deficiencies that they're addressing as we speak.
We're picking it up next week after a thorough walk-through, in which they've promised to fix anything that's broken. Of course, I'm sure it'll be up to us to point out problem areas, so I've developed a quick list of things that need to be observed/checked. Feel free to add to the list or comment accordingly.
(Before we go any further, yes, it needs new tires which we figured into the pricing and are dealing with separately. They're also replacing carpet, awning, and slide topper.)
List as follows (in no particular order)
****CHECK FOR WATER LEAKS ON ALL PLUMBING****
****Expose water pump and water tank area, watch for leaks****
Entry door latch
Entry door plastic piece for screen slider - broken
Refrigerator – “check” light was on at previous visit, check operation in gas and electric
Front storage door – not latching
Water heater – gas and electric
A/C
Furnace
All interior lights
All exterior lights
All driving lights
Sealing around corners
Sealing above front storage door
New battery
Both propane tanks filled
Stove – all burners
Oven
Bathroom fan
Slider – In/out multiple times
Landing gear – up/down multiple times
Check awning
Check slide topper
Water pump
Ceiling fan
Smoke detector
Gas detector
Tire Air Pressure
Trailer Brakes
Breakway on trailer brakes
Microwave
Stove light and fan
Window latches and mechanisms
Make sure key matches trailer
Outside shower
Operation of manual vents
Check the plugs and GFCI’s
Open/close every drawer and cabinet
Visually inspect springs/axles
Check all hatch latches and hold-opens
  • you my friend have way to much faith in sales people. they don,t remember a thing about fixing things, never ever take a sales person,s word,, THEY LIE,, if it ain,t in black and white it ain,t there, CW known for not fixing things.
  • A pressure test would be a great investment even if you had to pay the $100.00 before final purchase.
  • TV's and antenna or satilight dish
    batteries under load
    ice maker if you have one check for leaks in back of fridge
    toilet seal be sure toilet holds water and doesn't leak out
    dump handles be sure tanks are flushed
    leaks around shower base
    CO2 detector, propane detector and fire detectors.
    Good luck and Happy Trails
  • As Judge Judy says......"IF it ain't in writing it doesn't exist"
    Used unit....ANY promises/warranties etc. must be in writing to be enforceable.
    Good luck with those 'verbal' commitments.
    Might I suggest you withhold full payment (10%) until AFTER repairs are completed. Oh wait I forgot they HAVE your signature already. Oops too late. (Notice how they don't take YOUR word)
    Check lists etc.
    Forum FQA..check out item #2.........LINK
  • I suggest you check the two online Wildcat forums for typical issues with the model Wildcat you are purchasing. I've been researching the Wildcat product line and one of the issues you definitely need to look for is cracks in the walls (exterior gelcoat), especially in and around all slides.
    Best of luck with your new purchase, I hope it exceeds all of your expectations!
  • Just be sure no money changes hands until you are satisfied with the repairs. That way you have nothing to worry about.
  • path1 wrote:
    And that "promise to fix anything that's broken" was in the paper work that you signed?
    You make no mention of the roof and they are a major part of RV. Not only to keep water out but very expensive to replace.
    No the promise was not in any paperwork, but 3 separate folks "promised" this. I'll take you for your word until you give me a reason not to. As of this afternoon, they were already checking and fixing some nuisance items I had pointed out. I'm primarily interested in major items (AC, fridge, etc.). I don't expect that they're going to fix every little wear/tear item, but I'm not leaving until I'm satisfied. Regarding the roof, it is what it is. I've inspected it as much as possible without tearing panels down. I stood with my head at the top of the ladder and watched someone walk from one end to the other to see if it had any issues. No water damage on the walls, no soft spots on the floor, no rusty nail/tack heads, no moldy smell.
  • And that "promise to fix anything that's broken" was in the paper work that you signed?
  • Regardless of how good your list is, you will miss something. Just make sure the "something" is not a big item. Best of luck!
