memtb wrote:
You may consider the drain connection being put in the grey tank drain line downstream of tank, but upstream of grey tank drain block valve (if possible). Just be "very" certain that your dump valve is open!   I believe that the thought behind this, is just in case your level indication is incorrect... you cannot have an overflow issue.
      In this post...I mentioned plumbing your washer downstream of the gray tank and "Not" into the gray tank!!!!
       The reason I suggest this is.... I just (this morning) winterized my washer. If you are plumbed into the tank you can not "visually" witness the washer pumping the antifreeze to drain. If you get a good pink color from the open ended sewer connection....then you know that you have thoroughly "winterized" the washer lines and pump. If it goes to the tank... you will never know if you got a "good" winterization!  Again...just my 2 cents worth!
