pugcrew
Jan 03, 2014Explorer
washer dryer prep unit just means it has been supplied for plumbing and electric. the vented unit I am referring to is the actual washer / dryer combo. This will require cutting a 4" hole in the wall to vent to the exterior. I have done this many times and it is very easy. I always start with the hole on the interior so if for any reason there is an obstruction (but never is) you can adjust the hole for a clear path to the exterior. if the hole needed to be adjusted it will never be seen once the washer is in place. Another way to get a hole location is wait for the morning dew to cover the outside of your camper. It clearly will show you where all your wall frameing is located. I still make a small probe hole on the interior just to make sure. I am a carpenter by trade so I am also the official hole cutter with all of our fellow campers. Good luck. Feel free to PM me if you want any advice.
About Fifth Wheel Group
