rrbowman
Jun 16, 2015Explorer
Larryect wrote:
I am thinking there is some odd wrinkle in the tank that changes due to the weight of the water.
Possibly I should open the bottom of the trailer so I can see better what is going on.......
I'm thinking that what has happened is that a brace or strap that holds the tank in place has broken and the tank when full is shifting or sliding because of the broken strap or bracket. I recommend that you remove the heavy plastic covering from beneath the trailer and look to see what is actually happening. If not the fixes you are thinking of trying will lead to a complete failure. I believe the tank is actually tipping over due to the bracket or strap being broken which would result in the toilet lifting and the vent pipe being forced upwards.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
