Hvyhauler
Jun 06, 2015Explorer
I have the Barker 42 gallon Supertank/4 wheel model.I replaced the rear hard plastic wheels with wider pneumatic tire/wheel assemblies & also replaced the front hard plastic wheels with lawnmower type metal wheels with lubeable bearings.
I dualled the front wheels/2 on each side and made a new front axle out of a 1/2 x 10 inch bolt.Filled to capacity the tank holds 348.6 lbs of water plus the weight of the tank.I can easily pull it by hand with the wheel modifications and its very quiet as it rolls through the campground.
The handle is also removeable and the tank can be pulled by your TV if going a long way to the dump station.I use it for gray water only.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
