cavie
Oct 26, 2019Explorer
wildtoad wrote:Lynnmor wrote:
It all depends on water quality and the quantity used. I replace when it is about half depleted or the wire looks weak near the fitting.
This is a good method. According to Suburban you should drain the heater when not in use, so plenty of opportunities to check it. The rods are cheap as is teflon tape around the threads, and I suppose Suburban has a good reason for using them in their water heaters.
Atwood is aluminium. needs no rod. Suburban is glass lined steal and must have a rod.You must drain the water in the winter to prevent freezing and breaking the tank.
About Fifth Wheel Group
