zigzagrv
Oct 29, 2019Explorer
"Ron if too much telfon tape is used the rod won't work because the treads need to touch the tank's treads. The reason I switched to pipe compound. Also the tank needs to have an air chamber. The relief valve can leak because of no place for the water to go when hot."
Larry, I don't use Teflon tape or pipe compound. Just a thin coating of grease on the threads so they don't seize/rust.
About Fifth Wheel Group
