Old-Biscuit wrote:
Remove rubber cover that has 'Push to Reset' on it
Check electric set of t-stats....one on left side with black wires.
Look to see of wire between top (high temp t-stat) and bottom (normal t-stat) is burnt into
Left set are 120V AC and right set (red wires) are 12V DC for propane.
Upper ones have 'reset buttons'
Well you where spot on with you post. The bottom black wire was burned thru and not connected. I guess my question now is why did it get so hot to burn up the wire and is the thermostat still good.
thanks again for you sharing your knowledge in helping me with this problem.
