SDcampowneroperator wrote:
Whats your altidude? Altitude makes a difference in % of air to gas mix, so a lean or rich mix will cause mis fire. When it does light what does it sound like look like?
A roaring flame is lean, lazy lean, quiet, yellowish. Clean blue with slight rumble is proper.
We have had to adjust the air intake (with tape over a bit of the intake) at low altitude to stop flame out from low mixture.
I'm at about 1500'. Everything looks good. Just seems like it won't cycle back on when the water temp drops after the initial start up.
