importman's avatar
importman
Water heater question
Hello again everyone, I have another question. My Montana has a Suburban water heater and I’m wanting to replace the anode rod with one that has a drain made on it. It’s cold here in the NC mountains so I have to winterize every time we come for a weekend and I’d like to speed up the process. My problem is that the rod that’s in it now is about 8 inches long and all I can find with a drain are about 4.5 inches long. Other than having to replace it more often is there any reason I couldn’t use one like that? They both have 3/4 pipe thread. Thanks in advance for your help.
  • I don’t think it will be any issue. I had never heard of that type of Anode rod, now I have to look it up
  • I would stay with the standard anode. Buy the proper sized socket, extension and ratchet to make it very easy to remove and install.
    The small drains can and will clogg up. You may think you drained the tank but guess what, you didn't!
