philtrains's avatar
philtrains
\Water heater red light question
I have a 2012 Crusader. The water heater on/off switch does not turn on when I turn the heater on. It does come on sometimes and then goes off. Any suggestions?
  • Allworth wrote:
    I have seen that on the electric side, but never in 14 years on the gas side.
    //One exception is where the owner has installed additional pilot lights (usually green LEDs) on the switch panel//
    Our previous 2000 Coachmen TT had a separate switch for the electric that looked like a household switch that had a red indicator light that showed the electric side was on. When you turned on the gas side a small red light would come on. When the burner lit then the red light would turn green. Wish my 2004 was like this.
  • Our older (1993) motorhome worked that way, switch on-water heater on if water heater fails to ignite red light comes on. Then we would have to turn it off then right back on and you could hear it light.
  • I have seen that on the electric side, but never in 14 years on the gas side.
  • Oaklevel wrote:
    ScottG wrote:
    As Gary said, it only comes on if there's an ignition problem.
    If it stays on then you have a problem.
    We had had both type switches for our water heater our last trailer switch light only came when there was an issue (pilot went out etc & was relighting)................... Our current water heater light switch is always on when you turn on the switch.............
    Interesting, what brand and year is your WH?
    Scott
  • My WW HWH switch light comes on when I turn the switch on, then goes off when the HWH ignites.
  • As Gary said, it only comes on if there's an ignition problem.
  • Is that the no-ignition default light? Only comes on when the water heater does not light.
