Old-Biscuit
Jun 13, 2015Explorer III
Water heater is attempting to light.....but main flame is not being 'proved' so power drops off gas valve and it closes.
It will make 3 attempts and then 'locks out' (Turn ON/OFF switch OFF to reset)
Spark electrode is either sooted up.....needs cleaned
Main flame is not engulfing tip of electrode.....needs repositioned
Weak spark/main flame not lighting.........check grounds. Check ceramic for cracks. Check wire connections on spark electrode and board
Main orifice plugged causing low gas flow....clean orifice
Burner tube obstructed......clean tube
In short.....like suggested above clean burner assembly & orifice
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
