allen8106
Apr 15, 2018Explorer
donn0128 wrote:
Actually it does. Dont believe it, connect each one and test yourself. Half inch would be OK IF you use only faucet at a time. Turn on two, or flush a toilet and watch the flow drop pike a rock. 5/8 might a bit harder to coil up, but you will get better flow.
You are still going down from 5/8" hose to 1/2" pex so there's no difference in volume. the 1/2" pex can only support so much volume. If you hooked a 2" hose to the rig, same affect. The 1/2" pex is only going to allow so much water through.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
