WTP-GC
Apr 15, 2018Explorer
jacksrbet wrote:
most RV parks have 1/2 suppy line to each site
That's a gross mis-statement. I don't believe I've ever seen anything less than a 3/4" water line. Then they install either a 1/2" or 3/4" hose bib, neither of which has a 100% port (orifice is less than nominal size). But the more limiting factors are pressure and the pipe size in the rig. Volume is based on pressure and if you diminish the pressure, the volume follows. Therefore, on a campers in most parks, I don't see how a 1/8" difference in hose size will be noticeable under 99% of circumstances.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
