- ksg5000ExplorerIf AC drips when raining - try tightening the 4 bolts. If AC only drips when running then chances are the drain holes in the pan which collects condensation from the evaporator coil have plugged up - need to clean them out.
- larrynExplorerMy ac has loosened up twice, removed inside trim tightened four screw no problem.
- TakingThe5thExplorerThat Cajun heat may have cooked your air conditioner gasket although your 5er seems too young for that to happen. Get on the roof, pull the cover and look for blockages.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
