jstaffonExplorerFeb 04, 2019Water leak at air conditioning ventI have a 2016 Rockwood 5th wheel with two Coleman Mach air conditioning units (the one in the bedroom being a heat pump). The rig also has two MaxAir exhaust fan units. Inside on the ceiling of the...Show More
freewayrandyExplorerFeb 04, 2019Pull the cover off the ceiling a/c unit and check the 4 bolts that hold the unit. They have a tendancy to vibrate loose.
Related ContentWater Heater Leak on start up.Water leakLeaking fresh water tankFunny water pump leakWater Pump
