donn0128
Feb 04, 2019Explorer II
Loose AC housing. The AC units are bolted down using 4 screws. Seal is provided hy a foam gasket. As the gasket ages it can shrink, the bolts can work loose. Either can allow water past the seal. Very carefully snug the bolts down evenly a bit and see it thst stops your issue. If not, buy new gaskets.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
