Bowhunter61
Dec 29, 2015Explorer
the bear II wrote:
How about the seal around the window.
On my 5th wheel the water traveled along the window frame and then down inside the wall. I noticed when I stepped in a big wet puddle in my carpet. Resealed the window and leak is gone.
I thought about that but that small square I cut above the vent, the oustide wood is still wet there and that is above the lower window. The top of the upper window is just under the rolled up awning so I don't think water can get in there. Plus the wall seems to be the wettest by the corner.
Maybe if it still leaks with the plastic on, I will dry everything back up and then run a hose on each window, just to be sure.
I have been running 2 big fans and a heater in the area to dry everything out.
About Fifth Wheel Group
