How many of you would like to have a water meter that told you how many gallons you had pumped out of your fresh water tank? Since the factory level gauges are so inaccurate I thought it would be a n...
I wouldn't want one. I really don't see the purpose. When the water in your tank gets low, you will refill it with your water jugs or take the RV to a water source. If you're at a full hook up CG, it won't matter.
But, maybe it would make you more aware of your consumption while boondocking?
