freewayrandy wrote:
Checked aerators, all OK. Checked pressure on the in-line regulator gauge reads 50 psi. pressure in rig lousy at that psi. Checked pressure at house and got 65 psi. Connected to rig with no regulator and had great flow that way. Guess I need an adjustable regulator and canister type filter. Checked that RV water supply site and may go with them unless I find that stuff locally. Thanks for all the input.
JFYI...
Many of the in line so called 'fixed pressure regulators' are misrepresented in their name and advertising imo. They in no way adjust(regulate)pressure. They are simple orifice type devices that just regulate flow, not pressure.
Its not even a 'fixed' flow rate. Since a higher inlet water pressure will result in more flow. A lower inlet pressure less flow rate.
So pretty much every word in 'fixed pressure regulators' is not correct.
Any true water pressure regulator would solve your problem.
jmo
