Old-Biscuit wrote:
Don't know what 'vacuum and hose assembly' is...cause there isn't any vacuum.
Suction side of pump??? Suction strainer..clear bowl assembly???
Pump internal check valve should stop water from flowing backwards thru pump when connected to city water.......should!
Is this what is leaking??? About $10
If can't find one soon enough..remove it and use 1/2" PVC plug...screw into end of pump
No that is not what is leaking. On the pump it has a strainer on the vacuum side but that not what is leaking. It's the housing on the end of the pump motor.
