- Itching2goExplorer IIX3 on Surflo Revolution. Just replaced my original SurFlo and am very impressed with how quieter it is compared to the one I replaced. Good product.
- poloaceExplorerInstalled the Sureflow revolution. Much quieter. Much better than the flowjet that was there.
Great pump. - poloaceExplorerThanks for the input
- lj2654ExplorerI installed a Revolution and can't even hear it running, but works great in my opinion.
- SCVJeffExplorer
Dick_B wrote:
I think its the 5.7 that was killed off, and the only thing close to that one is a FloJet. The models below that seem to run forever
Did you try searching this Forum for `water pump'? To minimize the responses search the results for `shurflo' or `revolution' Shurflo's latest, or other make.
Our Shurflo 4.0 has worked well for years but they don't make them anymore, I think. - Dick_BExplorerDid you try searching this Forum for `water pump'? To minimize the responses search the results for `shurflo' or `revolution' Shurflo's latest, or other make.
Our Shurflo 4.0 has worked well for years but they don't make them anymore, I think. - harold1946ExplorerWhat went bad the pump itself or the motor? In many cases the pump assembly can be replaced independently and is quite easily done DIY. It will save a few bucks.
What brand and model number? - SCVJeffExplorerHow deep are your pockets and how much do you care about noise? There is probably $150 delta between the various pumps out there.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
