srink
Nov 07, 2013Explorer
I agree with a lot of the others. But It sounds like you might be sucking air. The least little air hole can cause it to run and it's pulling air instead of water. check all connections,lines, stool, outside spikets, any where water goes. and especially where the line screws to the pump. When the pump is running, assuming it's not defective, it's because something is calling for water. this could also be why your pressure is down. I would check really good for leaks. something is telling that pump to kick on and you're not getting full pressure.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 16, 2026
