dave14117's avatar
dave14117
Water pump running...and running
In our Cameo 5'er we're on city water. Water pressure in the coach is pretty weak, think it's the regulator. Anyway turned on the pump to see if it would help. It did. But the thing is, the pump keeps on running and won't turn off after you turn off the faucet you tested with. No leaks I can see.
Any ideas are appreciated.
  • IF YOU HAVE A OUTSIDE SHOWER CHECK THE VALUE AND SEE IF IT IS CLOSED ALL THE WAY.
  • I'm not an expert but your water pump should be pumping from the fresh water tank. If you're using city water and don't have any water in the fresh tank I don't see how turning on the pump would help you at all. Actually if you're running the pump dry it will probably stay on trying to pump air and that will probably burn the pump up.
  • IS city water still connected?
    If it is the check valve may still be partially open and you are pumping water from your fresh water tank into the CG water system
