servitrike's avatar
servitrike
water pump
looking for some wisdom.
i have a 2010 Cougar 29' 5th Wheeler. the water pump makes some terrible noises when i turn it on.
i want to check it out but i have no idea where to find it. sounds like it is on the same side of the rig as the kitchen sink, the toilet, and the fridge.
in a prior rig(an older Class A)i found it under the bed in the rear.
can somebody point me in the right direction as to where it mite be located?
  • Its under the kitchen sink in our Arctic Fox. I brought a spare pump along to use to pump water from water carboys into the drinking water tank. Of course the installed pump died one afternoon but I was ready, an easy install I did change the orientation of the pump to make it easier to work on. I had to cut the rubber feet away from the old pump since the screw heads were too corroded to unscrew. I used corrosion resistant screws on the new pump.
  • I'd think that if it makes so much noise, you should be able to at least pin point the 'general' location of it??
    On my old Prowler, it was under the kitchen sink cabinet. On my new Rockwood, it's all the way in the back in the bathroom, inside a lower cabinet and about as far away from the fresh water tank as it can be!
    It's pretty quiet overall, but since the bedroom is up front, you can hardly hear it in the middle of night if used..
    Good luck! Mitch
