moonlightrunner
Nov 25, 2013Explorer
Easyheat pipe tape on hose (NOT SPIRAL WRAPPED), poly tubular pipe insulation completely wrapped with Gorilla tape. I have about 2 ft of tape hanging out both ends of the hose. RV side wraps around connect. Supply pipe side wraps around the hose bibb fitting. The hose bibb gets a Reflectix envelope bungie corded closed if it is an above ground pipe and Reflectix stuffed around the hose bibb if it is one of the inground type of water connections. The little sensor kinda hangs. I've not noticed that it touching something mskes a big difference.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
