jdc1 wrote:
Extend the overflow hose a few inches above the fresh water tank. That's how it should have been from the factory.
Thanks .Hard to tell at this point, they are running parallel , coming out thru a hole in the top of the frame just below the floor . So I am assuming they have to be elbowed out of the top of the water tank a couple inches , and run to the outside of the frame to drain the overflow . Unless they are plumbed into the side of the water tank at the top of the tank .
Only way for me to know would be to pull the underbelly ,and take a look . For me this not a great issue , but my son would like to be able to haul a full tank when boon docking ,considering his tank is only 56 gallons .
