JIMNLIN
Sep 03, 2019Explorer III
op wrote:
If the tank is located behind the axles, then I might not want it. A full tank (350#) would really effect the pin weight.
Not as much as you may think.
I've loaded many a GN and 5th wheel flatdeck trailers/stock trailers and was always surprised how little hitch weight changed adding weight just behind the aft axle. 350 lbs placed maybe 2' behind the aft axle changes hitch loads very little. How much it can change depends on several factors...the biggest is distance from the pin to the 1st or 2nd or 3rd axle and distance between each axle/etc.
I haven't looked but is there a owners forum for that brand trailer ?
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
