soren
Aug 18, 2016Explorer
bpounds wrote:
If it really bothered you, I'm sure it could be pulled down with some screws. Do it right, and use the right screws, and it would look like it was original.
I wouldn't recommend this. Assuming you could find a suitable substrate to hold the fasteners, as soon as the ambient temp. is 15-20* higher than when all the drilling and screw installation was done, the fiberglass sheet will buckle, and "inflate" between screws, and end up looking like some sort of failed upholstery project. The next issue would be what exactly would those screws anchor to? A nicely laid out pattern of surface fasteners will have exactly nothing in common with the surprisingly small amount of framing located in the rear wall. The screws will be hitting nothing but foam and very thin Luan. Overall, this would do nothing but look awful and create a few dozen more places to leak.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 23, 2026
