jornvango's avatar
jornvango
Explorer II
Nov 11, 2023
We just bought a fifth wheel! Several questions ...
We just bought a used 2009 fifth wheel to put on our land and live in while we build. The one thing that doesn't work on the fifth wheel is the battery so the first thing to do is to replace that.
Before we start buying stuff for the fifth wheel, we have a few questions that hopefully someone can help us with.
1) Since there is plenty of room in the battery storage compartment, we can pretty much fit whichever battery group size. Does the group size matter? In our old Casita trailer, we only had very limited room for 1 battery so of course we had to buy the correct group size. How does this apply to the fifth wheel?
2) The fifth wheel only as one battery (which is dead). We'd like to put at least two or three 12V AGM batteries. I assume we can connect the RV to one of these three, and connect the batteries in parallel (positive to positive, negative to negative) to keep the batteries 12V?
3) We're going to hook up a Renogy solar panel (with built-in controller). Do we simply connect the solar panel to one of these three 12V batteries?
Thanks!!
  • I would use two FLA 6-volt golf cart batteries wired in series.
    Yes, if your solar panel has a built-in charge controller you can wire it the batteries. You are going to need a few hundred watts of solar.
    Are you not going to have 120-volt power to build the house?
