allcool
Jul 04, 2014Explorer
Shadowman00 wrote:
Checked all the fuses and none are broke? Checked the 3 30 amp fuses by the battery and they all look good?
Well, I have the exact same TH, just longer. But before I bought it, rented a 2007 fsw 2800 a few times from camp n style. So I can say my fsw 3200 is exactly identical in its electrical set up. I am very familiar with all of its systems.
Sounds like maybe all the wires at the battery didn't get reconnected...?
Or maybe a fuse popped when you disconnected or reconnected the batteries..?
Just 'looking' at a fuse can sometimes not be accurate to determine a bad fuse. I've seen a few bad fuses that unless you inspect them very carefully, right where the fuse link connects to one of the fuse posts, they looked perfect. A bad fuse doesn't always have to have a black spot on the burned up link. Best way to check a fuse, especially located under the fridge on the fsw, pull the fuse and use a simple continuity meter.
jmo
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
