Shadowman00
Jul 05, 2014Explorer
We'll, I've looked at everything I can find. Tried to hook the batteries up per the picture and blew more fuses so I figured it wasn't that. I tried to isolate everything to one battery to see if I could figure it out? You guessed, nothing.
I don't know if it helps but I thought I would share what I'm working with. There are 2 black wires I'm connecting to the battery. One goes into a connector block near the battery box and there are no in line fuses. I have made sure the connection is solid. The second black wire goes into the floor and as I trace it, it appears to go to the on board generator (that won't fire). The white (positive) goes to the connector block near the battery as well and the several wires go off from there.
There has got to be a fuse I'm missing somewhere? If anyone knows of any other locations for a fuse on these things I would greatly appreciate it. I'm now going to go replace all the 20 amp fuses to see if maybe one just has a small crack?
Thanks for any insight!
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
