allcool
Jul 05, 2014Explorer
Shadowman00 wrote:By the way,,, on most trailers, black is positive and white negative...
There are 2 black wires I'm connecting to the battery. One goes into a connector block near the battery box and there are no in line fuses. I have made sure the connection is solid. The second black wire goes into the floor and as I trace it, it appears to go to the on board generator (that won't fire). The white (positive) goes to the connector block near the battery as well and the several wires go off from there.
There has got to be a fuse I'm missing somewhere? If anyone knows of any other locations for a fuse on these things I would greatly appreciate it.
Thanks for any insight!
My bet, you have a battery neg or pos wire connected wrong.
Post a pic of your batteries, any/all connections on the wall next to the batteries, and all wires on batteries showing how you got them connected. That might help us see your problem...
jmo
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
