Shadowman00's avatar
Shadowman00
Weekend Warrior Electrical Problem - Need Guidance
I am looking for assistance from the experts on this forum. I just pulled the batteries on my 2007 Weekend Warrior FSW2800. I took them to the local auto part store to test and to my surprise they came back at 100%, so I saved a couple hundred for the year!
Now comes the problem. Before I put them back in, I realized my 110 was plugged in, so to avoid problems I unplugged it. I heard one of the detector alarms go off, which I think is standard when they loose power? So I installed the batters 2 12 volt. Same process I use each year when I pull them to check?
I went to the monitor to see what the batteries read, and the monitor is dark? I tried a few of the lights throughout the TH and lights are working. I check a few other items and fridge is dark, hot water won't ignite, generator has no power? I found the fuse box under the fridge along with the 12v shut off? (Didn't know that was there). Checked all the fuses and none are broke? Checked the 3 30 amp fuses by the battery and they all look good?
The only common denominator I could identify is that all the items that are on the left side of the breaker block seem to work, and all the items with Black wires on the right side of the breaker block don't work?
I don't know if anyone can arm chair identify areas I can look, but I'm getting ready to leave on Thursday next week and know I won't have time to get an appointment to get it looked at? (3 weeks out). I don't think it is anything serious, I honestly beleive it has to be a fuse that I haven't been able to identify. However, I'm far from an electrician,with only enough knowledge to get me in trouble.
If anyone can provide some assistance, I would greatly appreciate it. Thanks in advance. Also,if there is additional information needed, I'm happy to povide.
  • Did you hook up the batteries backwards?
    Follow battery negative cable to frame ground....check that it is clean/tight.
    If you hooked up backwards.....swap cables then check the 2 large fuses on converter.they are 'reverse polarity' fuses and are probably blown also.
    With 120V unplugged..check for 12V DC on converter where battery cable connects.
  • Any chance it's inline fuse right next to the battery? Mine used to be finicky.
