JRscooby wrote:
valhalla360 wrote:
If you are doing a bumper pull with a WDH, it's a good idea to do a 3rd weigh (again $2.50) with the tension released from the bars.
I have seen this advice many times but have never understood what useful info is gained
Tells you what the weight distributing part of the hitch is doing.
Very useful if you are trying to dial in the correct tension on the bars. If the tension is too light, it may be distributing very little to the front axle and that would show up as a having almost the same front axle weight with and without the bars tensioned down.
