rhagfo
Oct 31, 2014Explorer III
ours wrote:
You all helped me understand a lot through this thread. I looked up information and found the pin weight to be 2,067 lbs, GVWR is 14,067 lbs Length is 36'11" I am new to this so all of this is a learning curve, we used to be tenters and then pulled a TT. Thanks for all the info you can give me.
TXiceman wrote:
Forget the dry weight and look at the trailers GVWR. Probably around 15,000# ..give or take.
A 3/4 ton cannot carry the pin weight when you load up for camping. maybe a 1 ton SRW but I'd get a dually.
Ken
The 5er has a GVWR of 14,067 lbs, Dry weight of 10,880 lbs., over GVWR likely, over Tire and axle ratings not likely>
The decision to run over GVWR is yours, and your alone.
I tow 11,000 lbs. with our 01 Ram and do great. You would be about 1,000 lbs. heaver than us, so take that into account.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
