Tgator1 wrote:
Truck: '13 Chevy 2500HD, cc, sb, 4X4, SRW, Dmax, Allison. Stock suspension, but will upgrade to Timbrens, and may look into air bags.
Looking at KZ Durango Gold G359RET: UVW 10640, dry hitch 2190, dry axle 8450, NCC 2960, GVWR 13600.
Hitch is a Reese 20k slider.
What is the trucks Rear GAWR? That will be your biggest issue. Dry hitch weight of 2190 will be close to 2,800-3K when loaded. Add to that the weight of the 5th wheel hitch and anything else you will carry in the bed, and you will find that you have exceeded the Rear GAWR. And that you should have gotten a 3500. And you will be 1000-1500 over the truck GVWR if that concerns you.
Chris
