Me_Again
Oct 30, 2015Explorer III
Hondavalk wrote:
This is from Ohio revised code:
GROSS WEIGHT: The weight of a vehicle
combination without load plus the weight of any
load thereon. the maximum overall gross weight
of vehicle and load imposed upon the road
surface shall not exceed eighty thousand
pounds
SINGLE AXLE WEIGHT: The total weight
imposed upon the road surface by all wheels
whose centers may be included between two
parallel transverse vertical planes forty inches
apart, extended across the full width of the
vehicle. The maximum single axle weight shall
not exceed twenty thousand pounds
TANDEM AXLE WEIGHT: The total weight
imposed upon the road surface by two or more
consecutive axles whose centers may be
included between parallel transverse vertical
planes spaced more than forty inches but not
more than ninety-six inches apart, extending
across the full width of the vehicle. The
maximum tandem axle weight shall not exceed
thirty -four thousand pounds.
Kinda dought many RVs have much to worry about.
Those a repeated from the federal bridge weight laws. Most states have the same in their code somewhere.
Some states like Washington license tonnage for private trucks. So you can be ticketed for being over our licensed weight or maybe over our tire ratings.
Chris
About Fifth Wheel Group
