45Ricochet wrote:
NMace wrote:
Yes, I have weighed my rig, I am well under all spec. ALL
Really :H
LINK
Say's here your GVWR is 8600, unladen was 5600. Also says Max towing 5k lbs.
LINK And this one states your campers dry weight is 8546 with a GVWR of 11176 and has a 12% pin ratio.
Maybe I looked up a wrong number or link. Or maybe max towing isn't a spec :H 12% pin ratio is about as low as I've seen though.
If you look at the tow ratings from Trailer Life, the tow ratings for the 1500HD 6.0 is either 8300 or 10,300lbs, depending on the rear axle ratio.
