larry barnhart wrote:
Cummins12V98 wrote:
I have NEVER said the Sailun is a bad tire!!! I simply choose not to support Communist Chinese Companies.
ESPECIALLY now!
My question what does your RV actually weigh FULLY loaded???
Hers is an option that is US Made and has a STELLAR record.
GY ENDURANCE ST255/85R16 33.1" diameter, Tread 8/32", Load E, 4080 lbs @ 80 psi 51 lbs
when I see Westlake tires on a new rv I know the reason is CHEAP. Not the reason I have bought the tires we use. Don't want cheap tires.
chevman
No idea yet, just bought it . Its empty now, I believe dry weight is just over 12K , which means nothing . GVWR is 15,500 same as my old Montana. Guessing loaded probably about the same as my Montana in 13,500 range, I don't pile stuff 4 feet deep in the basement .
You see cheap ,with Westlake, what do you see when they put the Sailuns on , I am going to guess same answer ?? Wetlakes ,and Sailun G rated tires are about the same price .
