Gray_Fox's avatar
Gray_Fox
Wet Bolt
What exactly is a wet bolt??? I want to check mine.
  • Gray Fox wrote:
    I. Can grease about seven fitting on each side of my tr. I guess those must be the wet bolt. am Ii right?
    Yes
  • I. Can grease about seven fitting on each side of my tr. I guess those must be the wet bolt. am Ii right?
  • Kit I used on mine - dealer installed it - 1 1/2 hours labor.
    Looks similar to this - I have not installed the angled zircs yet
  • They are the bolts which hold the leaf springs onto the trailer. You may or may not have wet bolts if you didn't install them yourself. I think most manufacturers just use 'dry' non-lubricated bolts.
