I have a 28ft 2010 Cougar and want to install wet bolts but do not have a proper place or equipment to do so. Has anyone had them installed by an RV shop and how much did it cost? Would I be better ...
The bolts (pins) that mount the equalizer and spring eyes are greasable and not dry like a standard pin. This allows the suspension pivot point to move easier allowing the suspension to float better and having the grease zerks keeps the pins free and pushes the dirt out. The pins and bushings should outlive the RV.
