bpounds
Aug 08, 2014Nomad
OP, you've got to stop worrying about the weight thing. Your F250 has the same drivetrain, axles, brakes, and frame as a SRW F350. Your tires and wheels may be rated lower than what they put on an F350, as I noted above.
Don't sweat the GVWR. Keep an eye on your rear axle load. I suspect you will not be over the 6,000# rating, but the scale will tell you. If you are over, you've got the air bags to level what the springs can't handle, and at that point the tires/wheels become your primary concern.
If you need higher rated tires, you can usually find take-off wheels on craigslist, from guys who have gone with custom wheels, and they go for around $500 for a set. A set of OEM 18" wheels and LR-E tires will get you some added capacity. I would stick with OEM wheels, because all the after-market wheels will be lug-centric and you should stick with hub-centric wheels.
About Fifth Wheel Group
