drillagent's avatar
drillagent
We've gone and done it now... Update
WE HAVE A 5TH WHEEL!! Drove four hours one way today to pick up our new to us 2012 Keystone Montana 3750FL. I want to thank everyone here for their wisdom, advice, input, and even their questions which made our walkthrough/PDI run so smooth today. Based on three years of research and prep through this forum, I drove up today in a 2012 F250 diesel SRW with B&W Companion 3500 and Air Lift suspension air bags. In my hands I had two different PDI checklists and recommended equipment gleaned from this forum.
After running through the checklists, we found three issues that were quickly taken care of. Two of the five slide outs were not seating properly and the awning was moldy and smelled bad.
Prior to hooking up, I inflated the airbags to 15psi in anticipation of the pressure increasing as load was applied. To my amazement, the truck didn't even squat. The loaded pressure was 30psi which I went ahead and bumped up to 40psi. The truck and the trailer sit almost exactly level.
I opened the jaws of the B&W companion and followed the ground guide directions to hook up. I got the stop hand signal and noticed the technician was locking the hitch. I didn't even feel or hear the hitch hit the kingpin it was so smooth.
So, all hitched up, all tanks and water lines emptied, and ready to go, we drove off into a torrential downpour which started just as we left. Did I mention this was the first time I ever towed a 5th wheel? Serious pucker time.
I was so worried about the rear axle being over weight, our first stop was the CAT scales about three miles up the road. We weighed the truck by itself before we went to the dealership. So here are the weights. BTW, the truck GVWR is 10,000lbs. GCWR is 23,500lbs. RAWR is 6,100lbs. Trailer dry weight is 12,500. Trailer tires LR E 3420lbs for total of 13680.
Truck alone:
Steer Axle - 4,940lbs
Drive Axle - 3,420lbs
Gross Weight - 8,360lbs
Truck and Trailer:
Steer Axle - 4,860lbs
Drive Axle - 5,760lbs
Trailer Axle - 10,680lbs
Gross Weight - 21,300lbs
Truck Total Weight - 10,675lbs
Kingpin weight - 2,340lbs
Trailer Total Weight - 13,020lbs
The drive home was amazing. I never expected the ride to be so smooth. I never heard or felt any chucking from the hitch. There was some pulling back and a few waves as we went across rough bridges, but nothing like I've heard others on the forum talk about. I set the cruise control at 60mph and it stayed there the whole way. Even through the Arkansas hills. I watched the engine and transmission temps very carefully, and they never went above normal. Even on such a hot, humid day.
Bottom line, I love my truck, I love my setup, I love my trailer. Two years to retirement can't go quick enough. Full timing, here we come!
  • Let the fun begin and start practicing at retirement. 2 summers will fly by for you. Nice looking combo too by the way.
  • Congrats! Good choice on the Montana - I here they are very nice fivers!
  • Bottom line, I love my truck, I love my setup, I love my trailer. Two years to retirement can't go quick enough. Full timing, here we come!
    You need to be a little more clear. It is difficult to understand if you are happy with your purchase. Ha ha.
