rerod
Nov 12, 2014Explorer
Doughboy12 wrote:
Oh, and replace the gasket and it "should" stop the leak...!
I see two big gaps.
I already replaced the gasket a while ago with no luck.
Iv been finding small puddles by this door for a while but remained on the linoleum.
This leak is confusing me. Because the interior siding is damp just ABOVE the door.. How, what?
There is a window way above this door.. But its dry all around it, and down the wall until, this door.
Which gaps, where? Lower corners have discolored caulk in them.
The new gasket is left off the bottom to help drain.
Id really like to remove it and the window and do it right but winter just set in here and I'm not in a good position and worried about damage. I did feel a bit of plywood swelling.
Doors shouldn't have latch bolts pass through thresholds.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
