Aug 13, 2015Explorer II
As Specularius said, they are your water system low point drains. Red is hot and blue is the cold side. They are used to drain the water system. The valves should be quarter turn. They may be a little stiff. Make sure you can open and close them before winter sets in. You might need to use them.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
