Jayco23FB's avatar
Jayco23FB
What axle do I have?
I want to upgrade my spring equalizers and shackles with a HD kit. I have a 2010 Jayco 23FB. How do I determine which axle I have?
  • What does the VIN tag on the off-door side (driver's side) front of the trailer give for GAWRs (gross axle weight ratings)? Is it 5200, 6000, 7000, etc.? Although tires will sometimes be the limiting factor, this would at least give you a starting place.
    Rusty
  • Jayco has a very good past model section on their website, should be on there. I doubt a label will be anywhere, I've replaced several and never noticed any.
    There may be a label in an interior cabinet if you're lucky.
  • Well you can crawl under rig and see if axle has a tag/data plate
    OR
    You can contact Jayco with your VIN and inquire
