JRS___B's avatar
JRS___B
What battery tolerates winter storage best?
We are snowbirds, but are about one month away from becoming sunbirds.
For several years I have had the original single deep cycle battery in our 36 foot fiver. No boondocking, just FHU RV parks. I flipped the battery switch off and that same old battery sat all summer with no maintenance charge. Yet it still works fine, but I will replace it because it certainly is time.
The future change in usage is that instead of being stored for 6 months in the summer, it will be stored for 9 months, including winter in Michigan.
My question is, should I just buy the same thing I have since this type battery has served me well, or should I be looking for an ungrade? I do not want to put in a new battery and find it will not accept a charge after sitting all winter in the cold, or maybe boil over because it is so dead.
Since I only need one battery, the cost is not a real concern.
  • Just a reminder, if the battery specs indicate CCA or Cold Cranking Amp's, it is not a true deep cycle battery! Ivylog indicate AGM, and I would have to agree, however being from FL I have no first hand knowledge of how they perfom in cold weather. If it is cold enough the battery can freeze, crack cells, and warp plates! At very least keep the battery compartment at least 32 degrees to prevent freezing.
